4gb sansa clip + songs
have 4gb sansa clip + it only has 330 songs and says its almost full what did i do wrong loaded off ps3. is there somthing i did wrong im new at this part 1st mp3 player any help would be great thanks again. it plays all songs on it now
You didn’t say what format the songs were in, or what bit-rate they were. If you’re loading FLAC format or WAV (as opposed to mp3 for example) then I could see where your memory could indeed be full.
im not sure about any of that if you can explain where to get that info from . the music was already on ps3 hooked up mp3 i just downloaded it.any help would be great the music was downloaded by using cds on to ps3 and saved.how would i fix this please help
Message Edited by william55am on 12-15-2009 06:45 PM
what is kbps. ps3 gives you from 96kbps 112 ,128,160,192,224,256 ,320 and ask for( codec-aac,mp3,atrac) if that makes any difference it was done on ps3 at mp3 /320 kbps
Message Edited by william55am on 12-15-2009 07:36 PM
Thanks for your help I understand now .
Miikerman wrote:   If you would like to fit more songs in, rip the songs at a lower kbps rate–in my humble opinion, 192 kbps still is a more than respectable rate.
And for others, 192 kbps would be the bare minimum with the mp3 format they could tolerate…so to william55am , try a couple different sizes, and see what sounds good to you…you’re the one that will be listening to them.:smiley:
