4gb Clip restarting by it self
Hello all! My 4gb clip had been work perfectly for a few months but now it keeps shutting off or turning on by it self. sometime it will last a few minutes sometimes just a few seconds before it decided to turn it self off. I’ve resetted the player and upgraded firmware and pretty much anything i could think off but the problem presists. (btw: it does this even while its connected to the computer)
ANY help would be great
Message Edited by 5up3r5t4r on 06-05-2010 07:23 AM
Miikerman wrote:
I do wonder if it is a hardware failure.
Kinda sounds like it. I’d call SanDisk Tech Support. If they can’t get it going for you, and determine it is a defective unit, they can set you up for a replacement under warranty. :smiley:
