Out of curiousity did you go to windows updates? Also check for optional updates. I can’t find it but there was a windows patch a while ago to allow drives above 2t I can’t remember which version of windows it was for.
Got the same problem. At first I suspected an issue with my USB 3.0 connection (card, driver, etc.) but using USB 2.0 did not help. I also had the problem with a 2nd drive of the same type, so it is not an isolated incident. I got what looks like file system corruption (files not found/can’t create new files) when the disk was about half full. Reformatting didn’t solve the problem. Out of frustration, and since I was running out of ideas, I took the drive out of the enclosure and connected it directly via SATA. (Note: if you do that, the disk will appear empty, probably due to the encryption, so you won’t be able to access your precious data any more… Make a backup first!) I changed the partition type from MBR to GPT and reformatted the disk in NTFS. It is now working like a charm. I suppose that this problem is related to MBR’s 2 TiB limit and whatever WD did to work around it. Or maybe the USB 3.0/SATA interface. Or the encryption. I don’t really care as long as the disk itself is sane. (I got the MyBook cheaper than an OEM disk, so I can’t complain.) I can’t believe that WD would sell a product as buggy as this. Next time I’ll buy an OEM disk and put it inside a 3rd-party enclosure with e-SATA or Firewire 800.
