I recently purchased a 32GB Micro SDHC card for my Fuze. I tested it with H2TESTW and it tested out fine, with no errors reported. Only problem, the Fuze did not recognize the card when using Rockbox. I had a similar problem when I bought the 16GB card. Is there a reason why the Fuze won’t recognize some SD cards versus others? Are there different formats of SD Cards? Thanks.
Is it recognized when using the OF (original firmware)? If it’s only happening when running Rockbox, seems your question should be directed on their forums, not here.
