Sometimes when I am watching a movie off of my 2TB passport, I can feel a “clicking vibration”. I don’t raelly know how else to describe it. There’s no audible clicks, and its more severe than the standard subtle vibration the device gives off. It only lasts a second and doesn’t occur at regular intervals. Is this something I should worry about?
Check if the link below helps. You can also run a test using DLG to be sure.
