I found this funny,
My computer, installed my SE as a MSC when I plugged it in and after 4 seconds unplugged it and then replugged it in for the first time.
To switch back to MTP I just deleted the MSC drivers related to the SE and then plugged the SE back in w/o unplugging it and replugging it in.
Haha, it’s funny. But I’m using Vista so I’m not sure if this trick works for XP or such.
I tried a suggested fix - reformat to Fat16. Still doesn’t recognize card and it total messes up playing songs - they skip as though the device is too busy indexing the card to play the song. This whole problem occurred when I foolishly updated my firmware from 1.00.15A2 to 1.01.01A2.
Called the tech support line - their story is that Kingston uses a different controller and won’t work with the Express. Ordered a Sandisk card with mini and std adaptors from Amazon ($30). We’ll see if that fixes the problem. I suppose I should be content with the base 2gb, but the slot is too irresistable.
Message Edited by pawinterks on 10-18-2007 11:33 PM
Anyway, Staples had a sale week of Columbus Day and they had Sandisk brand for the same price I paid for Kingston, so I guess I’ll just use it in my camera with the adapter.
Sandisk 2GB SDMicro arrived. Worked fine although I had an issue with the indexing not refreshing properly - showed songs and then wouldn’t play them. Turning off and then on finally forced a full refresh and things seem to be working OK now. If they could just get the resume feature to work correctly without having to resort to power off to save your place.
