# 2 TB MyBook Essentials Issues
**URL:** <https://forums.sandisk.com/t/2-tb-mybook-essentials-issues/350465>\
**Category:** External SSD for macOS\
**Created:** [December 14, 2016, 6:05am UTC](https://forums.sandisk.com/t/2-tb-mybook-essentials-issues/350465 "2016-12-14T06:05:42Z")\
**Posts on this page:** 2\
**Page:** 1
<div class="post-metadata">
**Author:** ![MellieMelMel04](https://avatars.discourse-cdn.com/v4/letter/m/a88e4f/32.png) [@MellieMelMel04](https://forums.sandisk.com/u/MellieMelMel04)\
**Post date:** [December 14, 2016, 6:05am UTC](https://forums.sandisk.com/t/2-tb-mybook-essentials-issues/350465/1 "2016-12-14T06:05:42Z")
</div>
Hello! I have had by 2TB MyBook Essential since 2012. It has worked great and I still have 1.92 TB of storage on it. I don’t use it often but keep it stored in it’s original box, upright, and cover it so dust does not get inside.
I recently updated my mac with Sierra. It was my first system update since I bought the computer (also in 2012).
Recently when I went to move files over into my MyBook… I plugged it in, I could access and read ALL of the files that I had previously saved to my hard drive but I could not add any more files.
When I first plugged it in to the computer it did ask if I wanted to back up my entire computer on to the macbook and I said no, because when I clicked yes, it said that it would erase the previous backup on the HD, and I was afraid it would erase the files I currently have stored. SO I cancelled it and clicked “no” the next time I was given the same prompt.
I then tried to drag a folder from my desktop into the Hard Drive, which have often done in the past with no problem. This time, however, it doesn’t allow it.
How do I fix this so I am able to save more files. I still have tons of space on this HD.
**Author:** ![ERmorel](https://sea2.discourse-cdn.com/sandisk/user_avatar/forums.sandisk.com/ermorel/32/65168_2.png) [@ERmorel](https://forums.sandisk.com/u/ERmorel)\
**Post date:** [December 14, 2016, 9:14pm UTC](https://forums.sandisk.com/t/2-tb-mybook-essentials-issues/350465/2 "2016-12-14T21:14:30Z")
</div>
See if the following link helps to solve the read only drive.
> **[Solving read-only conditions for external hard drives](https://www.cnet.com/tech/computing/solving-read-only-conditions-for-external-hard-drives/)**
> Along with the use of incompatible formats, errors can prevent a drive from being written to.
