First off: is there a place somewhere that I can review the release notes for previous releases of the firmware? I just recently updated from the .26 version to the .31 release. I don’t see anything compelling in the .31 version, so am planning to roll back to the .26 one in order to get rid of the slotRadio advertisement. However, I wanted to look at the list of fixes for the .28 release before doing so.
Of lesser importance: I operate my Fuze in MSC-only mode. On my external card, I created the same folders as are present in the root of the internal device memory. However, every time plug/unplug/refresh the device, it creates additional AUDIOBOOKS and PODCASTS folders inside of my MUSIC folder - in addition to the ones that I previously created in the root folder. It only does this on the external memory cards. Does anyone know why this is? Is there a way I can “fix” it? Or, should I just ignore it, since it really doesn’t cause any problems?
thanks.
[EDIT: question #1 has been answered well enough. Thanks to Conversionbox’s reply, I thought to search the knowledgebase, and found that it still had the release notes for version xx.28 listed, at least for the moment.]
Message Edited by txGreg on 01-25-2010 03:18 PM
