When I eject/disconnect my portable HD, my computer reboots. This happens on multiple Dell Win XP machines.
Weird, are you using the USB cable that came with the passport or another one? You can also run a test with DLG.
Yes, I am using the cable that came with my drive. it does it every time I disconnect the drive.
I don’t see that as avaialble software for my drive. Will it still work?
