Good luck I live in Türkiye, I live in Van. I bought 2 128gb and 16gb Sandisk memory cards from Amazon. If you use both for your phone, but I haven’t saved any formats. There are very important files for me and my family in 128gb. How can we solve this problem? Computer technicians in Türkiye solve this problem. We went to them and they said that Sandix is one of the most common carpet products. Video and photo recording will be done in 128 GB. A new SD card is needed in return. 16 GB does not have a recording feature. There are very important moments in 128 GB. But they said to save the IT department, but it was not possible. But with another method, 100/40 or so, it doesn’t matter. I will send it by cargo in SD card size.
Hi @Yunusturkey
(Get Support for Your SSDs and Flash Products | Sandisk)
(Contact Support | Sandisk)
If your 128GB card has important files and is not readable, avoid using it further to prevent overwriting data. You can try data recovery software that works with damaged or unreadable SD cards.
Run it on a computer using a card reader. If local technicians couldn’t recover the files, look for a professional data recovery service in Türkiye or ship it to a trusted one abroad.
Just don’t try to format or reuse the card before recovery—this can reduce the chances of getting your data back.
Try Stellar Photo Recovery software for recovering your photos and videos of your family from the card. It will help you recover those files from any situation, and you will be able to save them at another location. Just connect the SD card using a card reader, scan the card with the software, and recover your photos and videos to your computer, not back to the SD card.
Give it a try and see for yourself.
