128 GB microSDXC UHS-I unwritable after 2 months
I am using the microSDXC UHS-I in a RaspBerry Pi 4 booting Manjaro Linux.
All was fine until recently when the boot process hung in the startup/splash screen.
I tried re-writing the disk using the “dd” utility, but the original files remained.
Experimented a bit, but it seems that while the card is readable, is is write protected.
How do I disengage the write-protect??
Thanks much,
-KenD
Hi @KenDickey,
Write protection happens to prevent data loss from a potential fault. We recommend to backup your data immediately.
Please refer to the below link SD/SDHC/SDXC memory card is write-protected or locked
https://kb.sandisk.com/app/answers/detail/a_id/1102
Please refer to the below link SanDisk microSD memory card is write-protected or locked
https://kb.sandisk.com/app/answers/detail/a_id/6971
NOTE: If using a company computer, ensure your IT department does not block saving files to removable cards.
Please contact the SD Technical Support team for best assistance and replacement:
