128 gb help
I shoot video on the memory card it has become corrupt. Can not watch it
Micro sd ultra 128 gb class 10
Thank you
:smiley:   Hi Ofirf,
Dear member of SanDisk Community, welcome.
Friend, try with other card, to discard the camera.
Also, analyze the following (first stage):
1-   Please, clean the pins of the card and device slot, with isopropyl alcohol (or also, the medicinal).
2-   If still bad: test your card [MicroSDXC 128 GB c10], in other laptops, directly to its port-card (not USB card-reader).
     Also, see what capacity and format, shows.
3-   If still bad: in Start / My Computer, on the card icon, click the right mouse button, and then click in Properties/Tools/Error Checking and Repair.
Luck, and then you tell us, what happened, please.
Regards, Alfred.                                                            (Google translated)
hello,
did you buy the card from Ebay? because there are many counterfeit cards with 128GB and even 256GB cards and you can easily see them with incorect capacities and with the first use data corruption.
For more clarity about authentication you can contact the support.
Good luck.
