+1-855-869-6938 Why is my Epson printer not printing when ink is full?
Having an Epson printer that refuses to print despite full ink cartridges can be frustrating. While the ink supply is a critical part of the printing process, there are several other factors that can cause printing problems. Understanding the possible causes and how to troubleshoot them can help you get your printer back in working order. In this guide, we’ll explore the most common reasons why your Epson printer may not be printing even when the ink is full, and how to fix these issues.
1. Clogged Printhead
One of the most common reasons for an Epson printer not printing, even with full ink, is a clogged printhead. This issue occurs when ink dries up and clogs the tiny nozzles in the printhead, blocking the ink from flowing onto the paper. Printheads can become clogged if the printer is not used for an extended period or if it’s exposed to dry conditions.
How to Fix Clogged Printheads:
  • Run a nozzle check: Most Epson printers have a built-in function to check if the printhead nozzles are clogged. You can access this function through the printer’s control panel or software on your computer. This will print a test page that shows if any colors are missing or incomplete.
  • Clean the printhead: If the nozzle check reveals issues, run the printhead cleaning function. You can do this via the printer’s control panel or by using the Epson printer utility software on your computer. This process forces ink through the printhead to clear any blockages. You may need to perform the cleaning cycle multiple times to fully unclog the nozzles.
  • Manually clean the printhead: In severe cases, where automatic cleaning doesn’t work, you might need to remove the printhead and clean it manually. Be cautious with this method, as it involves handling delicate components.
2. Incorrect Printer Settings
Sometimes, the issue may be as simple as incorrect printer settings. If your Epson printer is set to the wrong mode, it may not print even if everything else is working correctly.
How to Fix Printer Settings Issues:
  • Check printer status: Ensure that your printer is set to “Online” and not in “Offline” mode. On Windows, you can check this by going to Control Panel > Devices and Printers, right-clicking on your Epson printer, and ensuring that the option Use Printer Offline is not selected.
  • Correct paper settings: If the printer settings are set for a different type of paper than what you’ve loaded into the printer, it may cause issues. Ensure that the paper size, type, and quality settings in the print dialog match the paper in the tray.
  • Cancel pending jobs: A stalled print job can prevent new jobs from being processed. Cancel any pending print jobs in the queue by going to the print queue (on Windows or macOS) and clearing it.
3. Outdated or Corrupted Printer Drivers
Outdated or corrupted printer drivers can cause printing issues, even if your ink levels are fine. The driver is the software that facilitates communication between your computer and the printer. If the driver is not working properly, your printer may not receive the commands to print.
How to Fix Driver Issues:
  • Update printer drivers: Go to Epson’s official website and download the latest drivers for your printer model. Follow the instructions to install the updated drivers on your computer. This can resolve compatibility issues and improve printer performance.
  • Reinstall printer drivers: If updating the driver doesn’t work, you might need to uninstall and reinstall the drivers. On Windows, go to Control Panel > Devices and Printers, right-click your Epson printer, and select Remove device. After removing the printer, reinstall the latest drivers from Epson’s website.
4. Air Bubbles in the Ink Cartridge
Air bubbles trapped in the ink cartridge can block the flow of ink, preventing the printer from printing correctly. This issue is particularly common with ink cartridges that have been refilled or handled improperly.
How to Fix Air Bubble Issues:
  • Run a cleaning cycle: Performing a printhead cleaning cycle can help dislodge air bubbles from the ink cartridge and restore ink flow.
  • Remove and reinstall the cartridge: Try removing the ink cartridge from the printer, giving it a gentle shake, and then reinstalling it. Be careful not to shake it too hard, as this could cause ink to spill.
  • Replace the cartridge: If air bubbles persist or if the cartridge is damaged, consider replacing it with a new, genuine Epson cartridge.
5. Ink Cartridge Compatibility or Recognition Issues
Even if your ink cartridges are full, your Epson printer may not print if it doesn’t recognize the cartridges. This can happen if you’re using third-party or refilled cartridges, or if the cartridge is not seated correctly in the printer.
How to Fix Cartridge Recognition Issues:
  • Use genuine Epson cartridges: Third-party or refilled cartridges may not be compatible with your printer, causing recognition issues. Switch to genuine Epson ink cartridges to avoid this problem.
  • Reseat the cartridges: Open the printer’s ink compartment and make sure each cartridge is securely installed. If a cartridge is loose or not properly aligned, the printer may not detect it.
  • Clean the cartridge contacts: Dust or ink residue on the cartridge contacts can prevent the printer from recognizing the cartridge. Use a lint-free cloth to gently clean the metal contacts on both the cartridge and inside the printer.
6. Print Spooler Problems
The print spooler is a service on your computer that manages the print jobs. If the print spooler is not working correctly, your printer might not print, even if the ink is full and the printer is functioning normally.
How to Fix Print Spooler Issues:
  • Restart the print spooler: On Windows, open the Run dialog (press Windows + R), type “services.msc,” and press Enter. In the Services window, find Print Spooler, right-click it, and select Restart.
  • Clear the print spooler cache: In the same Services window, stop the print spooler service. Then, go to C:\Windows\System32\spool\PRINTERS, and delete all files in this folder. Finally, restart the print spooler service.
7. Firmware Issues
Epson printers, like many modern devices, run on firmware. Outdated firmware can sometimes cause the printer to malfunction, even if the ink cartridges are full.
How to Fix Firmware Issues:
  • Check for firmware updates: Go to the Epson website and search for firmware updates for your printer model. Follow the instructions to update the firmware, which may resolve any issues preventing the printer from working properly.
8. Paper Jams or Mechanical Issues
Lastly, a paper jam or other mechanical issue can stop your printer from working, even if it has full ink cartridges.
How to Fix Paper Jams:
  • Check for paper jams: Open the printer’s compartments and check for any paper stuck inside. Remove it carefully, ensuring there are no torn pieces left behind.
  • Reset the printer: After clearing the jam, turn off the printer and unplug it for a few minutes before plugging it back in and restarting it.
Conclusion
There are several potential reasons why your Epson printer might not print even when the ink cartridges are full. By following these troubleshooting steps—checking for clogged printheads, updating drivers, resetting the print spooler, and resolving cartridge issues—you can often resolve the problem and get your printer working again. If none of these solutions work, contacting Epson support or taking your printer to a professional technician may be necessary to diagnose and repair the issue.
