+1-855-869-6938 How to Get Epson Printer Online?
Having an Epson printer go “offline” can interrupt your work, whether you’re at home or in the office. This issue occurs when your computer cannot communicate with the printer, usually due to a connectivity problem, incorrect settings, or outdated drivers. Fortunately, there are several ways to bring your Epson printer back online and resolve these issues. In this comprehensive guide, we’ll cover the common causes of the issue and provide step-by-step instructions to fix it.
1. Common Reasons for Epson Printer Being Offline
Before we delve into the solutions, it’s important to understand why an Epson printer may go offline:
Connectivity Issues
  • A common cause is a weak or lost connection between the printer and your computer, especially if it’s a wireless connection.
  • USB cables may become loose or faulty.
  • Network issues can disrupt the communication between your computer and the printer.
Incorrect Printer Settings
  • The printer may be set to “Use Printer Offline,” causing the system to prevent any print jobs from going through.
  • Printer queuing issues can also prevent jobs from being sent to the printer.
Driver Problems
  • Outdated, missing, or corrupted printer drivers can result in communication breakdowns, leading to the printer being offline.
Hardware or Firmware Issues
  • Problems like paper jams, low ink levels, or firmware that requires updating can affect the printer’s online status.
2. Initial Checks Before Troubleshooting
Step 1: Ensure the Printer is Turned On
First and foremost, confirm that your printer is powered on. If the printer is in sleep mode or off, your computer will not detect it.
  • For printers with a display panel: Check if there is a message on the screen indicating any error.
  • For printers without a display: Ensure that the power light is on.
Step 2: Verify Printer Connections
  • If using USB: Ensure the cable is securely connected to both the printer and your computer. Try using a different USB port or cable if necessary.
  • If using a wireless connection: Confirm that the printer is connected to the correct WiFi network. On the printer’s control panel, go to Network Settings to verify the WiFi status.
  • If using Ethernet: Make sure the Ethernet cable is properly connected to both the printer and router.
3. Getting Your Epson Printer Online in Windows
Method 1: Disable “Use Printer Offline” Setting
  1. Open Devices and Printers:
  • Click on the Start menu, search for “Control Panel,” and open it. Then, navigate to Devices and Printers.
  1. Check Printer Status:
  • Find your Epson printer in the list. If it says “Offline,” right-click on the printer icon and select See what’s printing.
  1. Uncheck Use Printer Offline:
  • In the new window, click on the Printer menu in the top-left corner and make sure Use Printer Offline is unchecked.
  1. Restart the Printer:
  • Turn off your printer for 30 seconds, then turn it back on. Check if the status changes to “Online.”
Method 2: Set Your Epson Printer as Default
Sometimes, if another printer is set as the default, your Epson printer may not be selected during print jobs, causing it to show as offline.
  1. Open Control Panel:
  • Open the Control Panel and go to Devices and Printers.
  1. Set Default Printer:
  • Right-click on your Epson printer and select Set as default printer. A green checkmark should now appear next to the printer’s icon.
Method 3: Restart the Print Spooler
The print spooler manages print jobs on your computer. If it’s not working correctly, the printer can appear offline.
  1. Open Services:
  • Press Windows + R, type services.msc, and press Enter to open the Services window.
  1. Restart Print Spooler:
  • Scroll down and find Print Spooler. Right-click on it and choose Restart. Wait for the service to restart.
  • After restarting the spooler, check if your printer is now online by attempting to print a test page.
Method 4: Update or Reinstall Epson Printer Drivers
Outdated or corrupted drivers can cause your printer to go offline. Updating or reinstalling the drivers can resolve the issue.
  1. Download the Latest Drivers:
  • Visit the Epson Support website and download the latest drivers for your specific printer model.
  1. Uninstall the Current Driver:
  • Go to Device Manager by pressing Windows + X and selecting it from the list.
  • Expand Printers or Print queues, right-click on your Epson printer, and choose Uninstall.
  1. Reinstall the Driver:
  • Install the new driver you downloaded from Epson’s website and restart your computer.
  1. Re-add the Printer:
  • After restarting, go to Devices and Printers, click Add a printer, and follow the on-screen instructions to re-add your Epson printer.
4. Getting Your Epson Printer Online on macOS
Method 1: Reset the Printing System
If you’re using a Mac, resetting the printing system can resolve many connectivity issues.
  1. Open System Preferences:
  • Click on the Apple menu and select System Preferences, then go to Printers & Scanners.
  1. Reset Printing System:
  • Right-click (or Control-click) in the printer list and choose Reset printing system. This will remove all printers, scanners, and faxes from your Mac.
  1. Re-add Your Epson Printer:
  • Click the + button at the bottom of the printer list to add your Epson printer back. Follow the on-screen instructions.
Method 2: Check the Print Queue
Sometimes, print jobs get stuck in the queue, causing the printer to go offline.
  1. Open Printers & Scanners:
  • Go to System Preferences > Printers & Scanners.
  1. Open the Print Queue:
  • Select your Epson printer and click Open Print Queue.
  1. Cancel Stuck Print Jobs:
  • If there are any jobs stuck, select them and click Delete. Then try printing a test page.
Method 3: Update Epson Printer Drivers on Mac
  1. Download the Latest Driver:
  • Go to the Epson Support website and download the latest driver for macOS.
  1. Install the Driver:
  • Follow the installation instructions. After installation, restart your Mac.
  • Go to Printers & Scanners in System Preferences and re-add your Epson printer if it doesn’t appear automatically.
5. Network Connectivity Troubleshooting for Wireless Printers
Step 1: Check WiFi Connection
For wireless printers, a disrupted WiFi connection can cause the printer to go offline.
  1. Verify WiFi Connection:
  • On the printer’s control panel, go to Wi-Fi Setup and confirm that it’s connected to the correct network.
  1. Restart Your Router and Printer:
  • Turn off your router for 30 seconds, then turn it back on. Do the same with your printer.
  1. Print a Network Status Report:
  • Many Epson printers allow you to print a network report that shows the connection status. Check for any error messages related to the WiFi.
Step 2: Reconnect Your Printer to WiFi
  1. On the Printer’s Control Panel:
  • Navigate to Wi-Fi Setup or Network Settings.
  1. Select Your Network:
  • Choose your WiFi network from the list of available networks.
  1. Enter WiFi Password:
  • Enter your WiFi password to reconnect the printer to the network.
Step 3: Assign a Static IP Address
Sometimes assigning a static IP address to your printer can help with connectivity issues.
  1. Access Your Router’s Admin Page:
  • Log in to your router’s settings page (usually accessible by entering the router’s IP address in your web browser).
  1. Assign a Static IP:
  • Locate the section for IP address assignments and assign a fixed IP address to your Epson printer.
  1. Re-add Printer:
  • On your computer, re-add the printer using the new static IP address.
6. Advanced Troubleshooting Tips
Tip 1: Disable Firewall/Antivirus Temporarily
Sometimes, security software can block communication between your computer and printer.
  1. Disable Firewall:
  • Temporarily disable your firewall or antivirus software and check if the printer goes online.
  1. Add Printer to Exceptions List:
  • If disabling the firewall resolves the issue, add the printer to the firewall’s exceptions list to prevent future issues.
Tip 2: Update Printer Firmware
Outdated firmware can cause connectivity issues. Check for available firmware updates on Epson’s support page and install them if necessary.
Conclusion
Resolving an Epson printer offline issue is usually straightforward if you follow these troubleshooting steps. Whether the problem is due to a network issue, incorrect settings, or outdated drivers, the solutions in this guide will help you get your Epson printer back online
