Newbie
i need a firmware to SanDisk Cruzer Blade 16 gb 1.10
usb information
Description: USB Mass Storage Device(SanDisk Cruzer Blade)
Device Type: Mass Storage Device
Protocal Version: USB 2.00
Current Speed: High Speed
Max Current: 200mA
USB Device ID: VID = 0781 PID = 5567
Serial Number: 200522434309F6B05D76
Device Vendor: SanDisk
Device Name: Cruzer Blade
Device Revision: 0102
Manufacturer: SanDisk
Product Model: Cruzer Blade
Product Revision: 1.10
Controller Part-Number: Unknown
SanDisk Guru
Re: i need a firmware to SanDisk Cruzer Blade 16 gb 1.10
[ Edited ]
There IS NO firmware for flash drives. What is it you are looking for and/or what is your problem?
Newbie
usb flash not working .and not appear on the computer
SanDisk Guru
Have you tried different USB ports and/or a different computer? If it's unseen by different ports or computers, the drive may be defective; you should probably call SanDisk Tech Support about a possible warranty replacement.
