Need help sansa clip
I have updated my version on my sansa clip , 1G , black . When i first buyed the sound was clear and loud . Now after upgrade the soung it’s over 50% less louder . What can i do to make it back to normal ? I barely hear  the music on the street.
this question has been ask a thousand times here. try using the search function. the short answer is thank the euopean union. it is to comply with EU law. basically you can get around it by resetting fatory settings and selecting rest of world for your region.
Check the fifth search result.
http://forums.sandisk.com/t5/forums/searchpage/tab/message?filter=location&location=Category%3Amp3&q=volume
Go to Reset Factory Settings under System Settings. Select English and for region choose something that isn’t Europe.
