turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
0
[Firmware] Sansa View Firmware 1.03.02 Download[ Edited ]Options
06-30-2008
12:55 PM
- last edited on
08-26-2010
05:12 PM
by
We suggest you update the firmware through the Sansa Firmware Updater. There is even a how-to video that explains the process. If for any reason the Sansa Firmware Updater does not work for you, feel free to continue by trying the more "computer savy" steps described below.
Sansa View Firmware | Instructions | Release Notes
Latest: 01.03.02 (As of June 30, 2008)
New Sansa Firmware Updater (Windows Version Only) - The latest Sansa Firmware Updater will update the View to the latest firmware. If you do not have the Sansa Firmware Updater it can be downloaded here: Download Sansa Firmware Updater
If you prefer to use the drag and drop file method, then please follow the instructions below.
::: Firmware :::
The 01.03.02 firmware is the latest release as of June 30, 2008 for the Sansa View. Firmware and release notes are available below.
WARNING: If you have an "F" firmware version on your device, you won't be able to update to an "A". But an "A" to an "F" version will work.
For (A) AMERICAS - Download ZIP file For (F) EUROPE w/ FM - Download ZIP file
Notes:
Fixes:
Enhancements:
0
Re: Sansa View Firmware 1.03.02 DownloadOptions
06-30-2008 02:25 PM
I was looking all over for the release notes. Thanks for posting this!
0
Re: [Firmware] Sansa View Firmware 1.03.02 DownloadOptions
07-03-2008 09:57 AM I see now tiy officially acknowlege MSC mode .. any chance of supporting a playlist option in MSC mode as well? m3u, etc.
Regards, Scott.
0
07-04-2008 01:50 PM
Thanks for the update. Now when are you going to fix the FM Radio reception problems?
0
07-11-2008 07:02 AM
When I saw the following in the release notes:
Inconsistent battery life for music playback
I thought you had fixed the bad battery life issue which was introduced with the 1.02.09 firmware (10-12 hours max with music). But the battery life is just as bad with 1.03.02. It did fix the lockups when using random playback though. Can the battery life be fixed to be as good as it was with 1.01.06. I got 20+ hours with that one.
0
07-11-2008 04:05 PM
And yet, still no shuffle fix.
0
07-18-2008 07:39 AM Hi...I just wanted to ask where do you find the links to download directly the firmware? I tried to browse http://mp3support.sandisk.com/firmware/ but it seems it's not possible.
Is there a way to look for updates without using the sansa updater?
Thanks
0
07-18-2008 07:51 AM
mmmm.... you seem honest: Just read this thread, you will find links at the very first post.
0
07-18-2008 08:10 AM yeah...ok...sorry....I didn't express myself very well....I found and downlaoded the link for the sansa view...I just wondered where I could find the same links for my old c250...
Thanks again
0
07-18-2008 10:57 AM
Be sure to check what c200 version you have by checking the back bottom right side of your device before loading firmware. |
