Accepted Solution
Compactflash: Ultra vs. Ultra II
Hi, I've seen the following cards:
compactflash ultra - 4GB - 30m/s
compactflash ultra II - 4GB - 15m/s
So, the ultra version is faster than ultra II one.
Which one is better then? Ultra II type has got other advantages?
Thanks.
Re: Compactflash: Ultra vs. Ultra II
the Ultra labeled cards are the newer updated versions with a faster transfer speed. there are really no other feature difference.
Ok thanks. :smileyhappy:
(Even if it's a bit confusing having ultra cards faster than ultra II... :/ )
is it mean "Ultra" is Compact Flash type I
and
"Ultra II" is Compact Flash type II ??
i little bit confusing about this...thx.
Nope. It's just a name used by SanDisk. All retail / professional cards from SanDisk are Type I.
Hi I have the same question, but I would like a more detailed answer please:
What is the difference between
Sandisk Ultra Compact Flash 8Gb  (up to 30mb/s.  200x)
and
Sandisk Ultra II 8Gb
My findings are that a Ultra II SDHC handles files much faster than the ULTRA CF cards,
is my CF card broken ?
