SanDisk Guru
Variable speed playback with automatic pitch correction
Variable speed playback  with pitch correction is so important when playing podcasts, lectures, and audiobooks.
I am now listening to lectures at 1.5X on my pc using Windows Media Player. It has automatic pitch correction. I wish I could do this on my next mp3 player(I don't want to use Rockbox).
SanDisk Guru
Re: Variable speed playback with automatic pitch correction
Well, that's your decision.....albeit one many disagree with. Smiley Wink
iPod Touch 5G 32GB, Touch 4G 32GB, Clip Sport 8GB.
Rockbox-> Clip Zip 4GB, iPod Nano 2G 4GB, iPod 5.5G 80GB
2012 Nexus 7 32GB, Asus MeMoPad 8 16+64GB, LG Optimus G Pro, Nokia Lumia 900, Nokia Lumia 520
SanDisk Guru
Some people just don't want the complications (installation or use) of a non-manufacturer's alternate operating system; or the possibility, however slight, of bricking their player through installing an alternate operating system; or the possibility of losing the ability to play files, such as library files or files from a music subscription or audiobooks service, protected by digital rights management, upon installing an alternate operating system such as Rockbox.
SanDisk Guru
Miikerman wrote:
Some people just don't want the complications (installation or use) of a non-manufacturer's alternate operating system . . .
Very true. For example, I love Rockbox on one of my e280's. I even taught myself how to make my own theme a couple years ago (which wasn't exactly easy, I might add and took me about 2 weeks). But I installed Rockbox on my Clip+ just the other day and couldn't stand it. Took it off a couple hours later.
There's something to be said for simple, press & play. If you want to tinker, adjust, fondle, customize and/or spend more time fiddling with all the options or playing games rather than listening to music, books, whatever that's OK too, but sometimes you just want or need the KISS system, Keep It Simple, Stupid.
SanDisk Guru
Agreed.  Just for pure music listening, devices like the sansa line of players are great.  They have great sound quality out-of-the-box and do not need add-ons nor adjusting of the equalizer for terrific sound.  Of course, there is nothing wrong with those that want to put in the extra effort to increase the quality level to their liking.
SanDisk Guru
I would think the improvement in battery life alone would make it worth installing for some people here. Smiley Tongue
SanDisk Guru
To each his own, I guess Smiley Surprised. The battery life jump on my Clip+'s when I had them was from barely ten hours to 15 hours, with my usual higher bitrate mp3's. If one was to use FLAC the difference is even larger.....from maybe 7 hours to  ~16 hours!
And with this  theme, it was just as easy, if not easier, to read than the OF was. I never play any of the games, etc.....I just listen to tunes. But it's nice to know that after a few minutes of setting up the backlight, scroll speed, and other settings, I don't ever have to do it again.
And let's not forget the most important thing.....no database refresh in Rockbox anymore! That alone, for those with 32GB cards, should be reason enough to switch.
SanDisk Guru
I may give it another go this weekend. Just received my Cortex CHP-2500 headphones recommended by you (Marvin) here. As I have all FLAC files on my Clip+ (and card) and need to burn-in the phones it would be nice to get more battery life.
SanDisk Guru
As you may have seen in one of those threads I linked to, some people find the cups to be too shallow, and feel their ears right up against the inner foam.....and so they stuff them with cotton or the like for more depth, like you can see here with mine.
SanDisk Guru
[ Edited ]
Yes, I did see that, but fogot about it until you just mentioned it. I only put them on and listened to a couple songs last night, but did notice they are a bit shallow. The "stuffing" idea is definitely something I'll have to look into. Additionally, those vinyl pad covers will have to be swapped out with the included simulated velour ones. My ears were sweating after only a few minutes! Smiley Surprised
