turn on suggestions
![]() Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Showing results for
Topic Options
SERIAL number - why not print on the cart itself?Options
04-21-2014 09:00 PM
Ok, first of all I know Rescue Pro is no longer supported by SanDisk..
But I am just wondering why SanDisk would not print the SERIAL number on the card itself?? Why put it in the packaging?? My packaging is all gone and now that I am trying to activate RescuePro it is asking for a serial number!
Re: SERIAL number - why not print on the cart itself?Options
05-30-2014 10:40 AM That's pretty much the practice for all devices including none Sandisk product. Just a thought though. |
