Newbie
battery charging & use
I'm new using the View, so I have a few questions concerning use and any tips and tricks would be greatly appreciated!
1.  Battery life seems to wear thin quickly.  Is there something I should or should not be doing to increase the charge?
2.  Is there a way to use the View while it is charging?  How long to get a full charge?
Thanks, b
SanDisk Senior User
Re: battery charging & use
Try using a wall charger. You can use the device if it is plugged into the wall.
Newbie
^^Correct!  I use my View as a selling point since I work at Circuit City.  Videos are the major drain on battery life so I just leave it plugged in and playing the movie at the same time Smiley Happy
