turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
0
Re: AVC SettingsOptions
08-09-2008 06:31 AM
Well I figured it out. If your using a widescreen source you need to go into Edit/options/video and selcet the option "Fit to width". Then it keeps the widescreen settings of the origonal video
0
11-05-2008 11:21 PM Use DVDFab and choose generic device. Open desired dvd or dvd folder. Doesn't have to be a main movie folder.
Set to: generic.mp4.h264.acc 320 x whatever comes up 128kps for audio can set audio up to 200% for more volume
0
11-06-2008 03:01 PM
someone explain container a little bit more in detail where is that anyway?
0
11-10-2008 06:26 PM What???
Container???
0
01-02-2009 05:19 PM I followed your instructions to the letter and I got the mpeg4 on my View. Now the problem is that I have sound BUT no image. What did I do wrong???? I have been working on this for days. PLEASE, PLEASE help
purpletanya
0
Re: AVC Settings[ Edited ]Options
09-17-2009 08:18 PM - edited 09-17-2009 08:39 PM Well now that I registered I can ask all my questions. 1) I seem to be converting the videos just fine but when I put them on the player alls I see is a picture of a video snapper thing (like the take 1 scene 1 thing). 2)I have tried every format known to man and it still wont work.
please respond back this is making me want to throw it out my window.
Edit: Ok I just tried to play the Blue Skys demo video but now that won't even show it's like my Sansa hates me now I'm really wanting to smash it... Message Edited by Vormund on 09-17-2009 08:39 PM
0
09-18-2009 08:41 AM You might have accidentally changed your View set to "video out"-mode.
Check your settings; (treasure chest)|Settings / Options|System Settings|Display|TV Out ... it should be "Off".
