Newbie
Re: "USB Device not recognized
Didn't even think about the SD slot. I do have an adapter, but don't have a micro SD card (only regular SD and xSD) but can get one cheap. It's a thought.
I don't think I can format the Fuze if Windows doesn't recognize it! That's the whole problem. Windows doesn't see the hard disk in it.It shows "connected" but there's the error message in the title, and it doesn't show up in Explorer.
SanDisk Guru
There's a FORMAT option in Settings > System Settings on the player. It can format itself without the need of a computer.
Newbie
Kewl! Will try that. As grandma used to say "couldn't hurt". (Well, it could if you lose files, but at this point, I'm going to lose them anyway, and I have most of the music and playlists on my computer.)
SanDisk Guru
Yes, formatting will erase all user-added content. so you will have to re-load the player from the files you have backed-up on your computer.
