Newbie
drained battery
I used the Fuse continuosly until the battery was drained.  Now it wont power on or recharge.
I plugged it into a usb 2.0 and usb 3.0 port, no luck..
Is this how it ends?  Did I blow this fuse?
Newbie
Re: drained battery
It works again.  I plugged the fuse into my notebook and its recharging.  It must be old age.
Newbie
Re: drained battery
This might be slightly off-topic, but .... My 8 GB Fuze is 2 years old.  I only use it for the FM radio (much better than Sony's Walkman radio).  It had been working about 20 hours before needing a recharge.  Suddenly it won't fully recharge, and dies after 4 or 5 hours.  Is this "normal old age" or should the battery still last as long as it did originally?
Newbie
Re: drained battery
I can't help but my fuse is collecting social security and the battery still lasts for 12 hours
