Go To
turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
0
Sansa Fuze problems[ Edited ]Options
01-09-2012 09:56 PM - last edited on 01-27-2012 08:05 AM Hi! About 2 months ago I uploaded Firefox download a bunch of songs onto my sansa fuze, everything was working fine. Then, about a month later, all the songs disappeared when I looked at Windows Explorer when the Fuze was plugged in. However, you can see and hear the songs on the Fuze. Also, some of the songs altogether disappeared. When I added new songs, you can see them in both locations. What are my problems here and how can I fix them? Thanks!
0
Re: Sansa Fuze problemsOptions
01-10-2012 07:35 AM Go to Settings/System Settings/USB Mode and change the mode.
Look at MSC and MTP. Your songs will be in one of them, depending on which mode the unit was in when you transferred them. Your computer can only see one mode at a time; the Fuze doesn't care how they got there.
Best to pick one mode rather than leaving Auto Detect. MTP is designed to work via Windows Media Player. MSC just makes the Fuze look like a flash drive. I prefer MSC, but you should probably pick the mode where your songs are already.
0
01-11-2012 04:18 PM I'm so glad the Fuze+ doesn't have this "feature". It's so nice to not have to care about modes. Tired of the Sansa Media Converter? Try Video4Fuze! It can creat smaller videos than SMC, and is WAY more reliable!!!!
0
01-11-2012 04:48 PM
0
01-11-2012 04:49 PM
0
01-11-2012 04:50 PM Ha! Great minds, etc.
0
01-12-2012 07:54 AM Jinx!
