In the past month i’ve been having problems, I cannot write songs on my fuze v2. It would have room however it could not write anything. I tried formating it using the fuze format feature in the settings tab. Nope, got rid of all my songs however when i tried to add songs to the player it would freeze. Like it would say transfering however it would not transfer. (songs on a micro SD could still be listened to though so it wasnt complete garbage)
So today i went at it. I plugged in the player, went to windows my computer screen, right clicked on the fuze and clicked format (quick format selected). Tried it, no change.
Then i descelected the quick format option The process took maybe 10 mins… What do you know it works. I did not need to reinstall a firmware or anything. After formatting the player the little hard drive would be empty however once you unplug it the " updating library" msg you see is what seems to install the folders.
Worth a shot.
Exact settings in the format screen
7.62
Fat32 (deffault)
allocation unit size 64kb
Volume Lebel
SANSA FUZE
format options (both off - unchecked)
(off) quick format
(off) create an ms-dos startup disk
