SanDisk User
Re: Sansa Fuze+ Firmware 02.38.06
[ Edited ]
I mean they should add some kind of submenu near "shuffle all" that lets you decide at least the letter from which you should  start the SLOW scrolling.
I wonder who decided to create the album menu, it's practically impossible to scroll albums. It does like 1 row per second...unbelievable.
I don't see any speed improvement
Newbie
Help Needed
I updated the firmware and now all my tags are screwed up. I only use flac files on my fuze. Instead of the name of the album it shows artist=name.  How can I correct this problem.  Anybody else having this problem?? Is this a bug in the new firmware??
Daniel
SanDisk User
I'd check your FLAC tags first with something like MP3Tag.
Newbie
[ Edited ]
After the update my Fuze+ is not seeing 131 songs. If I hook it up with USB I can see all the file there that I seen before the update. Somehow after the update even though all files are still pressent 131 are not being read. It reads other songs but not the 131 songs.
What can be done do fix this?
Newbie
Never mind I found out how to get them to show.
I was not aware of the folders option (thank you for this btw I loved it before). I went to folders and used shuffle instead of songs and it now shows all of the songs.
All I need now for the perfect mp3 player is to get it to not show album art and put the song info up there so it is a bit larger. I want this due to using it at work and in my car all the time. It would make it easier to see what is playing (when I choose to forward to the next song) at a glance.
Newbie
This version of firmware has following bugs:
  1. There is no option to choose method of locking, I prefer old one with keeping play touched.
  2. Songs in folder selection menu are not sorted properly, I have song without track number in tags, but in file names from 00 to 11, and they are played in very strange order: 1, 9, etc.
  3. Keyboard become too sensitive, too often back button cause too fast return to main menu and sometimes some accidental actions happen or taping in the middle cause to go up.
  4. Translation to Polish is incomplete. This is rather annoying. I can translate all of them for you, for free just send me strings to translate.
SanDisk User
I used to have the problem with the sd card not being recognized. It is still not resolved. It is no longer showing an error message, but now it just freezes during 'loading card'. Also since the first time I plugged in an sd card my clock does not advance anymore. This is not resolved by this firmware update either...
Newbie
I personally prefer the on/off switch being pushed to work for the lock button.
SanDisk Guru
[ Edited ]
This is not a "bug". And it's not new with this firmware update. The locking procedure was changed about 3 updates ago due to overwhelming requests and unhappiness with the way it was. Changing it to the power button was not only the majority of customer's preference, but also one that Sandisk could change and make everyone (except you and 2 others to date) happy.
SanDisk User
 I got the time bug again with this firmware too. I just wanna trash this product. seriously I can't take it anymore
