SanDisk User
Re: Sansa Fuze+ Firmware 02.38.06
[ Edited ]
Honestly I wish they added a real useful feature: navigation by letter in some way not that you have to scroll everything Smiley Indifferent
did they fix the sluggishness with sd + internal memory?
SanDisk Guru
You should try it for yourself, but I think that's what is meant by
Enhancements
Music content browsing by folder
Menu looping feature added
Audiobook sort order improvement
Low battery state early warning message added
Content library handling improvement
Let us know if things are better now. Smiley Wink
Newbie
Could be a pain for SANSA to get the firmware to add an alpha search without a QWERTY keyboard...???
Would be better (for me anyway) if the PLAYLIST's worked, then at least you could separate a large database of tracks into various smaller LISTS of music, then the scrolling within each LIST would take less time...
The Startup still takes AGES to load my 6.4k tracks......but other updates in 02.38.06 were most welcome, especially with the 'touch pad' response, maybe the sensitivity could have an option in SETTINGS??
Musak Luva
Newbie
The folder browsing doesn't appear to work that well at least for me. As far as I can tell it only browses things in the 'music' folder, I can't get it to browse podcasts or audiobooks on other folders.
Also anything that get's indexed via the genre tag into another section like audiobooks and podcasts doesn't show up via folder browsing even if it's placed in the 'music' folder.
Maybe I'm doing something wrong but it doesn't appear to be actual folder browsing since it is still reliant on tag data.
SanDisk Guru
you are not doing anything wrong. folder browsing only works for music.
Newbie
Ah yes spotted it says for 'music content'.
Still it's not really folder browsing, it's just another form of tag browsing dressed up to look like folder browsing, since things in that folder might not appear if they are tagged as audiobooks or podcasts. I don't really understand what it has solved.
Newbie
[ Edited ]
I have problem with flac format. If I have more albums for one artist, display me only one album - ,,RTIST=*name of artist*". (When I have only one album for one artist, sometimes display this too). Have anyone same problem?
Got the same problem after upgrading to the new firmware. I only use the fuze+ for playing flac files. Is there a way to go back to the previous firmware
SanDisk Senior User
You are right. Audiobooks and podcast do not appear.  I do like the fact that the player treats Podcast special.  This simplifies things for me in another area.
I have used the music folder browsing and it does work well.  I have files nested 3 folders deep.  They are not labeled Podcast.  I added them via Window Explore.  It works as I would expect.   When I add files via WMP, the Fuse+ sorts these files by author.  So Audiobooks with different authors each chapter are sorted in separate folder on the fuse.  Music folder view has no value in this case.
So, folder we want to view in the future in music folder view, need to be added  to the music section via Windows Explore.
Newbie
[ Edited ]
Thanks for the update.
One of the interesting bugs in this is caused by the looping menus... it's not a showstopper by any means.  When I navigate by Music->Artist, the looping menus cause some of the album art to be incorrect when I have more than 3 albums.  For instance, I have 5 albums by the same artist, and the third album is always the incorrect album art after looping; it is either the first album's art, or the last's.  The art is correct until I loop in the menu.
Like everyone's said - this is a quirky player.
Newbie
[ Edited ]
After updating firmware manually from 02.37.01f to 02.38.06f internal clock doesn't work correctely any more (24-hour mode).
it looses time after shut down. date doesn't switch to next day over night, also after turning off for only some seconds, time differs several minutes back (e.g. time was 9:05, when turning on it is 9:01)
Edit: Time bug in 24-hour and 12-hour mode. Switching time between 24-hour an 12-hour mode is sometimes saved as time where clock starts counting after restart, sometimes time differs several minutes.
