Newbie
Re: Sansa Fuze+ Firmware 02.38.06 Manual updating failure
I've just updated to 02.38.06… Two things so far:
  • If Sansa is locked, is it logical to allow change volume up/down (side buttons)? I would say "No": almost every day I get the situation when Sansa is playing in my pocket it and volume down is accidentally pushed, I can't hear the music. So I need to get it out, add more volume and put it back.
  • Would it be logical to remember the last position in navigation menu and restore it after power on? I mean, if I have navigated to Music → Folders (it's already tricky, as one need to scroll to last item, please add cycle scrolling – then it would be just one press) and then long way down to necessary folder, then after I have switched Sansa off and turned on again, it remembers the song, but I can't return to last folder.
SanDisk Senior User
Ithink that both of your suggestions would be great if they were options people could toggle. Personally, I prefer starting up to the main menu. I also like being able to adjust volume despite being locked since I normally hold it in my hand while walking (imagine skipping five songs because you had to dodge a drunk on a motorcycle).
--Pikidalto
Newbie
dma_k wrote:
  • [...] as one need to scroll to last item, please add cycle scrolling [...]
Go to Settings -> Customize Menu and set Looping: On. This enables wrapping around menus from last item to the first one. I turned this off on my device because it reacts erratically to my finger tapsSmiley Mad
Newbie
I wish this update had worked. I dragged the file into it. But what is the root file? I looked it up but it did not help. I don't think what I did caused anything to happen. A bit frustrated.
SanDisk Guru
@jtox
Be sure you have your fuze+ in MSC mode.  Go to settings, USB Mode and select MSC.  Then drag your extracted firmware.sb file into the root directory of your fuze+, which should show up as a drive letter in windows explorer.  Shows up as K:\ on my computer, but yours will be different.  Once it's copied over to your fuze+ you just need to disconnect it in order to finish the update.  Right click on the fuze+ folder in windows and select eject from the menu before disconnecting to be on the safe side though.
Hope this helps.
SanDisk Fanatic
FYI, unlike other Sansa players, the Fuze+ doesn't need to be in MSC mode. A firmware update can be done from either modes (MTP, MSC).
Tired of the Sansa Media Converter? Try Video4Fuze! It can create smaller videos than SMC, and is WAY more reliable!!!!
SanDisk User
I guess Sandisk is trying to kill this line off, no new updates in over year.  I'm going to have to go over to the darkside and buy a ICrap
Crystalyn
Sansa Children:E250,E260 V2, 2 4g Red Sansa Fuze, 4gb Red Sansa Fuze V2 and a 8 gb Silver Fuze(adopted), and 8gb Fuze +-Can't have too many Fuzes
SanDisk User
Don't do it!  Try a Cowon, that's my next choice when my Fuze+ eventually goes.
Newbie
