turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
0
Sansa Fuze- 'FAT is corrupted. Please connect device to PC and recover FAT.'Options
11-27-2011 09:21 AM
I will keep this breif: I have encountered problems with my Sansa fuze (seems to be common), with the stated error message. I removed the Fuze from my computer, whereby I was given the message 'Upgrading Firmware'. It froze. I turned the device off, and then found this 'common' error. I have not yet found a fix from the many forums I have been through. Thank you in advance for any help. I CANNOT connect the Sansa Fuze to the PC (Win 7) as it is 'unrecognised'.
0
Re: Sansa Fuze- 'FAT is corrupted. Please connect device to PC and recover FAT.'Options
11-27-2011 05:35 PM It sounds like your firmware update got interrupted partway through and scrambled the Fuze's tiny brain.
Uninstall the Updater from your computer. There won't be any more updates. Then update manually.
Go to the firmware link and download the two firmwares (1.x and 2.x) from the All Regions links.
http://forums.sandisk.com/t5/Fuze/Sansa-Fuze-Firmw
Unzip them--you'll find two folders with fuzeA.bin inside. Name the folders so you know which is v1.xx.xx and which is v2.xx.xx
It's essential to get the Fuze connected. The way that works most forcefully is:
Hold the power switch up for 15-30 seconds, long after it goes black.
Slide the power switch down to click into Hold position. You'll see an orange dot in the slot.
Connect the USB cord to the computer. Open Windows Explorer (Computer).
Hold the << and connect the Fuze. With luck the two drives will pop up.
Look inside the Sansa Fuze drive for version.txt. That should tell you whether you have version 1.x or 2.x . They apply to two different pieces of hardware--2 is not an upgrade of 1.
Drag the appropriate FuzeA.bin over to the SansaFuze drive, just drop it right onto the driveletter.
Unplug and your firmware should upgrade.
If you can't connect, try a different USB port on your computer--back ones are better on laptops. Or try a replacement cord (under $5 for a generic at Amazon or from cellphone accessories sellers--make sure it is for Fuze or Sansa E200--NOT AN IPOD CORD).
You can't do it without a connection, so if it's impossible to connect say goodbye to the Fuze.
0
11-28-2011 12:30 PM
No connection. Tried several USB ports on many different computers. I'm doubting that a new connector will make a difference. Thank you, anyway - I appreciate your help.
0
11-28-2011 12:41 PM By any chance is it still under warranty?
0
11-28-2011 09:49 PM If the cord is damaged it could make the difference. The fact that your computer sees a USB device means some connection is being made. IIRC there are two data pins and two charging pins--if one is damaged, you might get a strange response.
But Tapeworm is right. If it's under warranty, just call SANDISK for repair/replacement. |
