Newbie
Replacement leather case.
Where can I find a replacement case, like the one that came with the player? I also like how it has a hole for the headphone jack.
SanDisk Guru
Re: Replacement leather case.
Shop around online (eBay, Amazon, Google, etc.). You might find one, but remember this is a very old device so you may have to hunt a while. Smiley Wink
Newbie
Yeah, I had looked before posting, and seen something like this:
https://www.amazon.com/HappyZone-Silicone-Adjustable-Fishbone-Keychain/dp/B0047HLPLA/ref=sr_1_3?ie=U...
It looked bulkier than the leather case, though.  I didn't want to add something bulkier.
This one seemed to be the same case:
https://www.amazon.com/Crystal-Screen-Protector-Fishbone-Keychain/dp/B004IROT1C/ref=sr_1_28?ie=UTF8&...
Doesn't Sansa still make the fuze plus?
I couldn't find it, but do they still have cases from their site?
