Newbie
Re: Out of order audio book
I have essentially done all that is described in this post and still my book chapter order is, 1-a, 1-b, 1-c...10-a, 10-b... etc all the double digit chapters appear after the first chapter.
I downloaded Mp3Tag and changed all the track numbers and they are in order. I made sure each chapter was labeled  exactly the same except for the track numbers which are sequential and the titles of the chapters which show like this in the Fuze:
1-01 1A
1-02 1B
1-03 1C
1-04 1D
1-05 1E
1-06 1F
1-07 2A
1-08 2B
1-09 2C
1-10 2D
1-11 2E
1-12 2F
10-01 19-A
10-02 19B
10-03 19C
10-04 19D
10-04 19E
10-04 19F
Follows down 11, 12, 13, 14, 15, 16, 17, & 18, then goes back to 2-01 1A  etc
This is sooooo frustrating.
What else can I do to make this work? I have never had this much problem downloading.
I even used mp3tag to add a digit to the chapters with single digits, 1 became 01, 2 = 02, 3=03, etc still didn't help.
I have just split the chapters into two files. I hope this works otherwise I will delete the double digit chapters, listen to the single digit chapters then reload the double digit chapters. What a pain!
Thanks for any suggestions
Margie
Newbie
Just to be clear... The critical part of your comment is that the 'track #' id3 tag needs to be in read-order sequence or just delete the track #'s all together. The track # appears to overide any other tag when the fuze sorts the display.
SanDisk Guru
I'm sure the previous poster has been holding her breath for 2-1/2 years for your answer.
Newbie
[ Edited ]
Possibly not. But as I'm sure you're aware, other people (including myself) who have this problem consult these forums for solutions. This was a very frustrating issue and I would have appreciated finding the solution in here.
Newbie
This works like a champ!!!!! Just re sequenced 4 books and they all play correctly now.
http://kb.sandisk.com/app/answers/detail/a_id/8369/~/playing-audiobook-chapters-in-sequential-order
Newbie
