SanDisk Fanatic
Re: Need help.. How can I open my sansa fuze mp3-player?
Rather than take the whole thing apart (which could ruin your device, just like it did mine), or risk frying the electronics with water, you could perhaps clean the thing using a method I found in some other post. Basically what you do is get a piece of cloth, such as a towel, get it wet, and place the Fuze on it, facing down. The water *should* seep into the device, and clear away the gunk. Some people have apparently reported that doing this as many as two or three times has helped make the thing work a little better. Of course, there is no guarantee.
Good luck, all Smiley Wink
Tired of the Sansa Media Converter? Try Video4Fuze! It can create smaller videos than SMC, and is WAY more reliable!!!!
