Newbie
Fuze Help
I recently had a problem with my sansa fuze and the problem is that when I turned my fuze on the players onscreen text had symbols on it, and I was wondering if anyone could help me fix this.Smiley Happy
SanDisk Guru
Re: Fuze Help
Reinstall the firmware using the manual procedure from this thread: http://forums.sandisk.com/t5/Fuze/Sansa-Fuze-Firmware-Update-01-02-31-amp-02-03-33/td-p/139175
Newbie
Re: Fuze Help
Thanks! I just updated the firmware and it worked. Thanks again @Black-Rectangle:-)
