Administrator
Sansa Clip Zip Firmware 01.01.21
[ Edited ]
Firmware is the software code that powers your Clip Zip. You can think of it as the operating system.  SanDisk actively and periodically updates the capabilities, functionality, and reliability of the Firmware.  For an optimal experience with your Clip Zip, SanDisk recommends that you update your Firmware with each new release.  It’s fast, easy, and free!
SanDisk has released firmware version 01.01.21 for the Sansa Clip Zip. Download links and the release notes are available below.
Windows Users can Connect the device in any Mode and follow the instructions below.
Mac and Linux users can connect their Clip Zip in MSC or Auto Detect mode and follow the instructions below.
MSC mode instructions:
  • Turn on the Clip Zip
  • Navigate to Settings on the menu of the device
  • Scroll down to System Settings
  • Scroll Down to USB Mode
  • Select MSC
 Sansa Clip Zip Firmware 01.01.21 Download and Installation instructions
Manual Firmware Update (Download and Instructions)
Manual Firmware Update (All Regions) - Click here to download
All languages are now in one firmware version. After firmware update you will need to select your Language and Region preference.
• Remove any external card from the Clip Zip before performing firmware update
• Ensure your battery is > 50% full.
• Plug in your Sansa Clip Zip to your computer.
• Extract the clpza.bin file from the .zip file you just downloaded into a folder on your computer.
• Once extracted, drag the file to the root directory of your Sansa Clip Zip
             Note: If connecting in MTP mode drag and drop the Firmware file to the root of the Internal
             memory Folder
• Disconnect the Sansa Clip Zip and let the firmware update begin.
• Once it finally finishes doing its update, it will turn itself off.
• Turn the Clip Zip on, Select your language and region preference
• Once its back to the main menu, head to "Settings" >"System Settings"> "Info", and verify the "Version" is now 01.01.21"x".
                    Sansa Clip Zip Firmware 01.01.21 Release Notes
This new firmware has various enhancements and bug fixes, including key fixes listed below. Upon completion of the firmware upgrade, the device will turn off; power on the device to complete the upgrade process.  If the device does not initiate or complete, press & hold the Power switch for 15 seconds to reset the device and then press and hold power button again for 1 second to restart.
  • Enhancements
  • No new enhancements
  • Bugs Fixed
  • Device hangs up after finished playing special mp3 files, which contain CRC error at the end of frames
  • Known Issues
  • Recently Added doesn’t update Rhapsody transferred tracks
  • Artist Info page doesn’t display for Rhapsody transferred tracks
  • UI issues in Hebrew mode
  • New recording file sequence does not work correctly when previous recording got deleted
  • Text scrolling direction in Hebrew and Arabic is not correct
  • FM reception strength is not so good
SanDisk Guru
Re: Sansa Clip Zip Firmware 01.01.21
Hmmm, imagine this!   Smiley Happy
SanDisk Guru
Yes, this is the version that 2 people have aleady cited bugs with, having received a new player with this version from the factory.
1.) http://forums.sandisk.com/t5/Sansa-Clip-Zip/Clip-Zip-has-loud-burst-of-static-at-the-end-of-some-tra...
2.) http://forums.sandisk.com/t5/Sansa-Clip-Zip/New-Clip-Zip-strange-version/m-p/296845/highlight/true#M...
Engineering, I understand could not replicate the problems but strangely enough, backdating the firmware to the 01.01.20 release seems to have rectified the issues.
SanDisk Guru
iPod Touch 5G 32GB, Touch 4G 32GB, Clip Sport 8GB.
Rockbox-> Clip Zip 4GB, iPod Nano 2G 4GB, iPod 5.5G 80GB
2012 Nexus 7 32GB, Asus MeMoPad 8 16+64GB, LG Optimus G Pro, Nokia Lumia 900, Nokia Lumia 520
SanDisk Guru
Yet
SanDisk Guru
Yep.
Newbie
[ Edited ]
why there is no information about elapsed time/total time when playing a song ???
firmware Version
V01.01.21A was installed on my player, i bought it last week.
iam using german language settings and playback songs from 8GB MicroSDCard
SanDisk Guru
Because somebody at SanDisk thought they knew better than the people who actually use these things about what is needed (or wanted) on the display screen and what isn't.
This has been requested from numerous users from Day 1, but SanDisk has not added it.
SanDisk Guru
I just don't get it when tech. companies ignore basic and logical consumer user needs . . . .   Smiley Sad
Newbie
So i have had my 8gb clip zip for about 2 years as of november. it has worked fine up until a year ago. Without a micro SD card the player will not work. Neither the usb connection or the main menu itself will not show. I have tried the 01.01.21"x". update and nothing. It stays at V01.01.21A.
can anyone help me?
