I get “Application Not found” when I try to unzip the file “clipzip01.01.21.zip”. Please help. Thanks!
Could you perhaps explain the steps you followed?
Easiest way to get the latest firmware: manually download the latest firmware (no Firmware Updater needed, consuming PC resources)–follow the steps in the firmware thread at the top of the forum here; unzip it, using your PC’s unzip utility or freeware such as 7-Zip; and then install onto your player–again, following the directions in the firmware thread.
Perhaps this will help.
