Newbie
Accepted Solution
New Battery
I can't find a replacement Battery in my Country Germany.
Can anybody help, please?
Trank you in advance!!
SanDisk Guru
Re: New Battery
the battery is not replaceable.
Newbie
Re: New Battery
Of course it is. I have already opened the device, all you need to do is to solder 3 thin cables to the device.
SanDisk Guru
Re: New Battery
when a company says the battery is not replaceable it means opening the device will void warranty and they do not sell the batteries. sandisk's own user manual states the battery is not replaceable. you may be able to solder a replacement battery to the board if you can find one and if you can there is no guarantee it will work.
SanDisk Guru
Re: New Battery
If I recall correctly, I found 1 or 2 replacement batteries at aliexpress.com, at a good pricing; eBay may have listings as well.  Of course, as noted above, you--the user--need to do the replacement work.
SanDisk Guru
Re: New Battery
Replacement battery, via eBay.com:  http://www.ebay.com/itm/Original-Sandisk-Sansa-Clip-Zip-4gb-8gb-Replacement-Battery-Pack-303038P-/40...
(Same item/seller also is listed at eBay.de:  http://www.ebay.de/itm/Original-Sandisk-Sansa-Clip-Zip-4gb-8gb-Replacement-Battery-Pack-303038P-/401...)
Unfortunately, not inexpensive.  As the seller notes, there are three solder points to contend with (and tiny little wires).
SanDisk Guru
Re: New Battery
And a 3-page thread, with pics, discussing what needs to be done.
http://www.anythingbutipod.com/forum/showthread.php?t=55110&page=3
