Newbie
Mistakenly pressed language other than English
Help!  I was half asleep and was pressing wrong buttons and pressed Arabic or Farsi or whatever this is but it's not English so now I can't even bring up the right screen in Settings to change it back to English because I can't read what it brings up.  Any suggestions?
SanDisk Guru
Re: Mistakenly pressed language other than English
Very easy to fix . . .
Clip Zip:
1. Select Settings (image of an Mechanical Gears).
2. Select the 1st from the list to go to System Settings (System Settings is the 1st option under Settings).
3. Select the 9th item to access Language.
4. English should be the top (or first) choice. I believe it say English regardless of what language the player is set to.
Newbie
got to gears ,pressed select and didnt see anything that resembled settings
