My earphone jack doesn’t make a tight enough connection with my jack. Is there a way to open up the case and tweak the jack contacts?
Much obliged for any help in this matter.
Is your player new? If so, the jack just may be tight–it typically is; just be sure to really push the plug in hard and all the way the first few times–it’ll then loosen up.
Thank you for that post! I was getting ready to send mine back… it would cut out and would jiggle lose. I hated pushing it in so hard, afraid I’d damage something. You did it right! Thanks! Works great now with my little X-mini speakers that are great also!
