Newbie
Accepted Solution
Changing Between Radio Presets (Can't use left or right)
Do I really have to go to "Options>Presets" and then choose a station every time I want to go to a Preset?
Is there a way to avoid this?
Would Rockbox solve this problem?
Thank you very much for your help.
SanDisk Guru
Re: Changing Between Radio Presets (Can't use left or right)
Pressing the center Select button cycles through your presets.
Newbie
Thank you. I can't believe I didn't think of that. I guess I'm used to other control schemes.
Thanks a lot.
SanDisk Guru
Don't feel bad. This button command is not really intuitive.
No more often than what I use the FM radio, I still find myself tapping the right or left buttons too to scroll up or down through my presets . . . then realize that isn't working and have to remember how to do it with the center Select button. Problem is, you have to scroll through all the presets in order to go back just one. If you have like 15 or so stations set, this can be time-consuming and aggravating.
There should be a way to scroll in either direction . . . but unfortunately there isn't.
SBP
Newbie
Very helpful-thanks!
