poor volume
Even when i listen at highest volume the sound is ferry poor. What can i do about it??
I have the same problem. I have no solution for the time being.
If the region is set to Europe then reset it to something else. After that, set the volume to high in settings. Using the equilizer will reduce the volume, so don’t use it. If the volume is still too low, then use more efficient headphones.
Reset under the Clip’s settings, and choose N America or Rest of World when asked for the region.  Or reapply the firmware and choose one of those regions.
The High volume setting to then choose is also under the Clip’s settings.
Choose Reset under the Clip’s settings, and choose N America or Rest of World when asked for the region.  Or reapply the firmware and choose one of those regions.
You can also turn the equalizer settings up to max to get more volume, but the equalizer burns up the battery in no time.
