Newbie
Accepted Solution
audio books
I just purchased Sansa Clip + 4GB. I have read the manual & there really is no info on how to download audio books (I purchased from audible.com). This is my 1st experience with an MP3 player device. Any help with how to get audio books onto sansa clip would be greatly appreciated.
SanDisk Senior User
Re: audio books
Where are you at in the process? Audible.com is where I'd go to find instructions for downloading their books.  Sorry, I don't use Audible for my audiobooks, but I'm sure there's someone here who can help if you're having trouble transferring them to your player.
SanDisk Guru
Re: audio books
You need to download software from Audible and follow the directions here to transfer the content to your player.
SanDisk Guru
Re: audio books
Definitely follow the instructions at the Audible website.  If I recall correctly, you setup and use the Audible Download Manager (or something called something like that) to download and transfer to your Clip.
Newbie
Re: audio books
Thanks for the replies. Especially Tapeworm - thanks for the link to Audible! I successfully downloaded 3 audio books last night. WMP just seemed way to complicated and way too many steps.
