Newbie
Accepted Solution
Volume Control
[ Edited ]
Anyone know of a way to increase the volume of the sansa clip+ , other than the volume rocker
SanDisk Guru
Re: Volume Control
Under the player's system settings, there should be a volume option that you can set to high.
Note:  when you set your region originally on the player, if you set it to EU, the high volume option has been disabled (per EU regulations).  In that case, to get it back, either reapply the firmware or choose reset all under the system settings, and then chose one of the non-EU region options.
Newbie
Re: Volume Control
[ Edited ]
Reset factory settings then chose one of the non europe region options set the volume to high now it's all good, thanks for your advice
SanDisk User
Re: Volume Control
I too have had a problem with volume.   I have followed the above suggestions... it is still too low?   I did have the Setting to "North America" and have now changed it to "Rest of the World".  Still low?   Any other options?
SanDisk Guru
Re: Volume Control
Do you have the volume option set to High in the settings?
SanDisk User
Re: Volume Control
This is where you feel like an idiot.  But I am willing to share.   I had looked at all the controls and where they are when the player was given to me as a xmas gift.   Never had one before.   Of course, after awhile when you do not use things you forget about them.  So, I went back and reviewed the manual.  And there was the answer to my problem.   As you look at the Player on the left siide is the toggle for Volume control!  Duh!!   Evidently, in the process of putting this in my pocket several times the volume got turned down. Sooo, when I pressed it to increase volume,,,  it worked great.    A lesson learned.    Smiley Embarassed
SanDisk Guru
Re: Volume Control
PackGy wrote:
This is where you feel like an idiot . . . As you look at the Player on the left siide is the toggle for Volume control!  Duh!!
Don't feel too bad. There have been others who have posted here asking how to increase the volume on these things who missed that too. Smiley Happy
Newbie
Re: Volume Control
[ Edited ]
I too am an idiot! Thanks for setting me straight - I didn't see the vol control on the left side and was ready to return it !!
Now it sounds just GREAT!
Newbie
Re: Volume Control
This thread is very important to me. One of the Clips I have purchased has just lost the volume increase control (snapped right off the circuit board). This is horrendously frustrating. It's good to know there's a software fix so I can pump up the jam.
