Newbie
Sansa Clip+ volume control
SanDisk Guru
Re: Sansa Clip+ volume control
Yep, it has it.   Smiley Wink
SanDisk Guru
Maybe it's the volume limit problem imposed by the European Union? Under Settings/System Settings, reset it to Factory settings and then when it asks for Region, don't put Europe, use Rest of the World.
SanDisk User
grougeux, you probably deleted your post. But how did this worked out for you?
SanDisk Guru
More likely he hit the POST button accidentally before composing his message, and didn't notice he could edit it or delete it and start over by clicking the OPTIONS in the upper right-hand cormer of the post.
His other post and subsequent replies can be found here.
On most forums, a moderator would have deleted this empty post as part of his normal house-keeping duties. Smiley Indifferent
