Newbie
Accepted Solution
Sansa Clip+ microSD & microSDHC Cards (Max Size)
Hi just had a few questions about upgrading my Clip+
- What Card can the Clip+ take?
- does it load slower off the card the bigger it is?
- Once pluged in I use Windows Explorer to copy MP3's to Clip+. Will the microSD card still work like copying to Internal Memory?
Cheers
SanDisk Guru
Re: Sansa Clip+ microSD & microSDHC Cards (Max Size)
A Micro size. :smileytongue:
Just messin' . . . The largest size card now is 32GB and it will work fine in the Clip+.
As far as playing? No. But the database refresh that occurs after you disconnect from the computer will lengthen accordingly as the card fills up with more files.
Yup. Just remember, if using MSC mode there will be 2 distinct and separately labeled drives, like F: & G:. The 1st will be the Clip+; the 2nd will be the card slot. This occurs whether there's a card inserted or not.
Cheers
Newbie
Are you sure about the 32 GB card?
check the link below. it says expandable up to a max of 16 GB.
http://kb.sandisk.com/app/answers/detail/a_id/4986
SanDisk Professor
 I have a 32gb micro sd in my clip+, it works.
SanDisk Guru
It's possible that, at that time, 32GB cards were not yet available--they are relatively new.
Others have reproted success with 32GB cards as well.
Newbie
thanks !
well, great to know this small thing can take additional 32 GB....that is like 40 GB of songs....wow !!!
Newbie
Where did you find a 32gb micro SDHC card?  I've never found one over 16 gigs.
SanDisk Professor
Mine came from Amazon, but I'm in the UK so I'm not sure if every Amazon site sells them.  Sandisk sell them directly from their store if not.  The prices are kinda steep though.  I just really wanted one Smiley Happy
Newbie
Hi all,
I own a SanDisk Sansa Clip+ 2 GB MP3 Player (Black) and I'm curious if a 64GB microSD card will work with it. Has anyone tried this?
Thank you.
SanDisk Fanatic
That link clearly says 32 GB in first couple of lines!  I have trouble filling an 8gb card, you guys must have a lot of music!!
