I have loaded and tested a few of the items and sansafix, once again, was right on the money with what we could expect and the turn around time was great considering the fact that the Thanksgiving holiday was mixed in there.
Overdrive/Netlibrary FF bug is fixed…tested and confirmed (in fact long MP3 files is more stable as well during FF)
sandisk is pretty fast with these new firmwares! thank you for the msc only mode, it fixes a lot of problems with other people. i still don’t understand why we can’t see MTP files in MSC mode. it would be useful as MSC refreshes 10x slower.
regardless, i’d still like a lower minimum volume so i don’t have to run this every time i put on new music. also my new sennheisers are coming and i fear the dB reduction f mp3gain will make it unlistenible / battery killer at max volume
I just told someone at work to hold off buying a clip for Audiobooks because of the Overdrive FF issue. A quick check looks like it is now fixed. I’ll try the fix again on my walk tomorrow and if FF works, I’m shouting BUY, BUY to everyone I know. Thanks, Hodge.
Thanks!
Is there a fix to allow more steps in volume control (so the radio can be played quieter).
Also, volume normal/loud and equalizer only function on audio files not radio–is this intentional?
I’m so pleased with this update! The clip is now perfect for me - I was starting to get a bit panicky because I was running out of time to return it if I couldn’t get it to work with audiobooks. ;) Happily, it seems to be working fantastically!
FF works great!! Last week I literally had to remember where I was on a track, calculate how soon to turn on the Clip before walking so it would play over what I’d listened to the morning before. The new update works great!
One further note, last night I shelled out $205.00 at Costco for an X-mas Ipod Nano that the youngest daughter has to have - sure, it will probably run circles around the Clip, but that kid will do without or shell out her own money to replace her Nano if it is stolen (a hot item right now) or lost. Me, I’m out about 40 bucks if the Clip is lost. Thanks Sansa!!
Volume minimum still loud. Radio is almost unlistenable in a quiet room, just too loud. I can’t recommend this device to anyone until the minimum volume setting is modified.
