Newbie
Re: Sansa Clip Firmware 01.01.35 & 02.01.35 Release
Marvin_Martian , thanks. I see now, Nort America region in 02.01.35 doubles the sound level. U made me happy!Smiley Very Happy
SanDisk Guru
Glad I could help!
iPod Touch 5G 32GB, Touch 4G 32GB, Clip Sport 8GB.
Rockbox-> Clip Zip 4GB, iPod Nano 2G 4GB, iPod 5.5G 80GB
2012 Nexus 7 32GB, Asus MeMoPad 8 16+64GB, LG Optimus G Pro, Nokia Lumia 900, Nokia Lumia 520
SanDisk User
Pretty much what I was going to say -- no new features, fixes to stuff that I've never seen an issue with, but happy/surprised that a new firmware came out for the classic Clip.   Thank you, Sansa!
gwk1967 wrote:
I'm a bit disappointed in the lack of new features, but at least maybe this will silence the "Sandisk has abandoned us!" complaints.
Newbie
Do not update your clip with this firmware if you wish to use it with your car hi fi system.
Sansa have sneakily enforced the dumb regulation from Brussells to reduce the volume.
When driving, it is almost impossible to hear music over the road noise.
I would never have updated my clip if Sansa had advised that this was going to happen.
SanDisk Guru
If you'd taken the time to read a little bit here, you would know how to fix that low volume problemSmiley Wink
SanDisk Guru
Smiley
Funny, the shaded (sticky) thread directly below this one you posted in has the answer to your problem. In fact, it is titled
Low volume after upgrading firmware
Don't know how much plainer, simpler or easier to find the Admin could have made it. Maybe if he used flashing N E O N lights in the Subject title?
Newbie
This thread should be sticky, it points to the last firmware.
The current sticky thread points to the previous release (0x.01.32)
rockbox developer
clipv1 1GB, clipv2 2GB, clip+ 4GB
fuzev1 4GB, fuzev2 8GB, c200v2 2GB
Newbie
[ Edited ]
Hi!
Can you add to Sansa Clip in the future - headphones (left/right) balance control? Smiley Wink
Thanks!
SanDisk Guru
Kingkong wrote:
Hi!
Thanks!
Kinda doubt it, since it's discontinued and there probably won't be any further firmware updates.
Maybe with the Clip+, it would be possible but it would be up to SanDisk whether A.) it can be done, and B.) they want to do it.
Newbie
Ok. Thank you!
