Newbie
Re: Sansa Clip Firmware 01.01.35 & 02.01.35 Release
For getting back the volume gain, there are a very simple steps to do:
1) Settings -> Reset All -> Yes
2) Choose Language
3) Choose North America
To correct the FM frequency step for European users:
1) Settings -> FM Settings -> FM Region  -  Change from USA to WORLD.
Thats it. Enjoy Your Sansa.
Newbie
[ Edited ]
Firmware for V2 isn't working for me.
When I unzip the archive, I get a message that says, "inflating: m30pa.bin                bad CRC fbf19c9c  (should be f7c4e4eb)"
When I disconnect the clip, it says it's upgrading the firmware, then when I turn it back on it's still at version 02.01.32.
I redownloaded the file in case it got corrupted, but same results with that one.  Anyone know what the problem might be?
Message Edited by starcycle on 05-31-2010 10:15 AM
SanDisk Guru
I just tried it. It worked fine for me.
Newbie
[ Edited ]
>> edit: I don't know what's different, but it worked this time.  My finger might have slipped off the center button when I was mounting or plugging in the drive the first time. v02.01.35 successfully installed now, thanks.
Okay, that's good to know. Unfortunately it doesn't seem to help on my computer. I just updated a v1 clip using the same computer and that worked perfectly. Does V2 have to be unzipped on windoze or anything to do with windoze?
Message Edited by starcycle on 05-31-2010 10:41 AM
Message Edited by starcycle on 05-31-2010 10:43 AM
csp
SanDisk User
[ Edited ]
I have just finished updating the firmware, but can't see replay gain. Should it be under the Settings menu?
edit: I have found it. Thanks for the new firmware SanDisk
Message Edited by csp on 06-01-2010 03:49 PM
Newbie
I've got a v2 and, no doubt about it, ReplayGain does not work. I've tried using WMA files and MP3 files, and it's definitely just ignoring the ReplayGain tags. The pre-gain setting does seem to make every song louder, but it's not actually doing any leveling.
Newbie
I have noticed that when I copy a WMA (without DRM) file into my v1 clip, the file does not show up on the clip. This happens ONLY in MTP mode and with WMA. When I use switch to MSC to transfer the same or other WMA files, they show up fine. Other formats (OGG and MP3) transfer fine in both modes. I'm not sure if this problem began in this firmware or is a known problem from before. Are you guys experiencing the same thing or is it just me?
Newbie
Hi. I have a problem with release 02.01.35 in SANSA CLIP 2G.  I have uploaded it via UPDATER from 02.01.32, that was delivered in shop.  The soud level dropped tragically. Then I listening outside I can here nothing, this level is good only for silent room. In menu I can't find any more sound level settings as Normal and High.  Please advise to rise sound level or how to install earlier release.
SanDisk Guru
Please read this
iPod Touch 5G 32GB, Touch 4G 32GB, Clip Sport 8GB.
Rockbox-> Clip Zip 4GB, iPod Nano 2G 4GB, iPod 5.5G 80GB
2012 Nexus 7 32GB, Asus MeMoPad 8 16+64GB, LG Optimus G Pro, Nokia Lumia 900, Nokia Lumia 520
Newbie
Oh, it looks better now, I have returned version 02.01.32, sound is good now.Smiley Wink
