SanDisk Guru
Re: Sansa Clip Firmware 01.01.35 & 02.01.35 Release
Didn't people say here in the forums that the last firmware revision (last month) added Replaygain (and even though SanDisk hadn't said anything about that)?
SanDisk Guru
It seems to have been only on the V2 models.
iPod Touch 5G 32GB, Touch 4G 32GB, Clip Sport 8GB.
Rockbox-> Clip Zip 4GB, iPod Nano 2G 4GB, iPod 5.5G 80GB
2012 Nexus 7 32GB, Asus MeMoPad 8 16+64GB, LG Optimus G Pro, Nokia Lumia 900, Nokia Lumia 520
SanDisk Senior User
My 8GB Clip (and I think the 8GB models were only v2 flavor) does indeed now have ReplayGain with the new firmware.  I can't comment if v1 hardware does but I'll take Marvin's word that only v2 hardware does.
SanDisk Guru
I wasn't able to check for myself on the V1 hardware......that's what people said over at ABI. I did see for myself the RG on my old V2 that I updated for its new owner.
Of course, it seems like everybody with a V1 has gone the Rockbox route anyways, so it probably doesn't matter to them.
SanDisk Guru
Am still holding out, for a finished and stable Rockbox build ...
SanDisk Guru
I don't have an original Clip anymore, so it is irrelevant either way.Smiley Happy
SanDisk User
So Replaygain options have been found in the ClipV2 version... but has anyone checked whether the stuff actually works? It doesn't for me, at least. MP3s with ID3v1 + ID3v2.3 (UTF-16) here. I have tried adding the extra field that MediaMonkey writes, no change. The only thing that makes any difference is the pre gain setting.
SanDisk Guru
I haven't found that the pregain setting makes a difference, either on this, or my Clip+......what RG does for me....
I analyzed my library's track volume, not album volume. This way, when I listen on shuffle all mode, the volume is roughly equivalent with each song that comes up.
Newbie
I have not seen it but may have missed it - I have a 8Gb clip plus purchased late 2009 and was wondering what the latest firmware was for that.
Thanks,
Rich
SanDisk Guru
Thanks,
Rich
The latest firmwares for all Clips (v1 or v2), regardless of capacity, are the ones in this topic.
NOTE: The newer Clip+ with additional features (most notably a microSD expansion slot), has its own firmware which can be found on the Clip+ board.
