SanDisk Senior User
Re: Sansa Clip Firmware 01.01.35 & 02.01.35 Release
czajunia wrote:
Thanks tnmats! It did the trick. I changed to North America and the Volume setting is there and it's possible to choose between 'Normal' and 'High'. That's exactly what I was looking for. When you select Europe this setting is unavailable for some reason. It must be a bug because I am sure it was there in the previous version even when selecting Europe - I am based in UK and have never selscted North America before.
As for Replay Gain I don't feel like I am gonna use if it requires any extra work. I just though it was a slightly more sophisticated setting to boost the volume that replaced a previous Volume setting I couldn't find.
Anyway, thanks again for your help guys! Much appreciated!
It's not a bug, it's due to EU regs that Sandisk followed.  I think it's a bit silly to have that reg but they did follow the law.  Sandisk left an easy workaround though.  The previous rev didn't have this setting at all (i.e. turn off the "high" mode for Europe).
Just make sure your FM tuner settings are for European useage.  In the US we have FM freqs. on the odd decimal place (i.e. 0.1/0.3 etc.) instead of the even decimal (0.2/0.4 etc.).  Glad they didn't couple the volume and freq. settings together. You'll like the fact that now your MP3s converted at the 44.1kHz setting will be close to correct pitch too (main reason I upgraded).
Newbie
[ Edited ]
tnmats wrote:
it's not a bug, it's due to EU regs that Sandisk followed.  I think it's a bit silly to have that reg but they did follow the law.  Sandisk left an easy workaround though. The previous rev didn't have this setting at all (i.e. turn off the "high" mode for Europe).
Gotcha. It makes sense now even though it's silly.
I didn't install .33 and .34 firmware but I am fairly sure that my .32 and the one I had before had a "high" mode under Volume settings in the European version. Unless I was using North American one without even knowing about that.
Message Edited by czajunia on 03-24-2010 03:30 PM
SanDisk Guru
That's good, since there weren't any firmware releases with these numbers. Smiley Tongue
The EU volume compliance was only added with this latest (.35) version.
Newbie
[ Edited ]
Still no folder browsing Smiley Sad
how do you do a hard reset?
Message Edited by dwaltz on 03-26-2010 03:54 PM
SanDisk Guru
Hard reset:  hold the on switch uppermost for 15-30 seconds.
SanDisk Professor
That's a soft reset.  I suppose the hard reset would be a format either via pc or the clip.
SanDisk Guru
It's just a reset. There really isn't a hard or soft variety any more, especially with the newer players. In the case of the e200 series (and previous) players, a 'soft' reset was holding the power button down for 15 - 30 secs. Some stronger medicine, in the form of a 'hard' reset was possible with these players where they had a replaceable battery. Pull the back off, remove the battery and let the offending gobbledygook dissipate from the memory stores by leaving the battery out for a few minutes. Re-install the battery, and now all the bad stuff has melted away leaving your precious Sansa player a veritable virgin again.
With the newer players, non-replaceable batteries and sealed cases, a 'hard' reset is impossible, so there's no need to differentiate between the two anymore. :smileyhappy:
SanDisk Professor
A hard reset is not necessarily taking the battery out.  Usually, for example, on cell phones, a specific combination of buttons will hard reset the device, restoring it to factory settings.  In the clip's case that would be a format.
SanDisk Guru
you need to go to the setting menu to reset to factory defaults
SanDisk User
I'd like to see ReplayGain on the v1's, any chance there will be another update?
